跳转到主内容
加入维修社区 - 创建账户
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
Front Bezel- Frankenstein Replacement?
Has anyone tried replacing the front bezel of a non-unibody macbook pro 17 " with the front bezel of a G4 powerbook 17"?
From pictures the strucutre looks similar, however, there may be two potential issues: the camera and the hinges.
Please let me know if you had any experience with this frankenstein fix or know if it might work, thanks!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
I've looked through the manuals for both and I will agree that they do look VERY similar (front, back and overall dimensions). I do not have both at my disposal so i cannot tell you if they will work or not. I would be curious of your results. The hinges shouldn't be a major issue, the camera might cause problems (as you also mentioned). You might have to dremel off some mounting tabs and use two sided tape to hold it in place.
这个答案有帮助吗?
得分 2
添加一条评论
Well, i think that needs some serious home engineering ;-)
As pierrej mentioned, a Dremel would be of tremendous value.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the help guys! However, I chickened out of the experiment..finally found the piece online : )
完成的
添加一条评论
添加你的答案
Dagrosap 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 646
