跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
Black Screen after screen replacement?
I recently replaced the screen on an iPhone 8 plus. The first screen I replaced had lines through it, so I replaced the screen a second time and the phone screen is completely dead. I can hear sound through the speakers (that emergency buzz when you hold down the power and volume down) and the phone is receiving texts through an Apple watch but a completely black screen. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
Was the battery disconnected when doing the screen replacement? If not backlight circuit may need to be fixed via someone that does micro-soldering. This can be confirmed by trying out the old screen and see if it works. If not try putting a flashlight on the screen and see if you can see display with a dim screen (might need to do it when the phone is turning on with apple logo).
这个答案有帮助吗?
得分 1
4条评论:
Alright so I tried it shining the flashlight on it and it does indeed show the display very faintly. What should I do next?
完成的
Ok so if it shows display faintly on all of the screens you'll need to take the phone to a reputable repair shop that does micro-soldering on iPhones.
They will be able to fix that problem for you as that requires a board repair.
完成的
I didnt undo the battery and my screen is black but vibrates and junk so is there any other way then micro soldering
完成的
you can try a new screen and see if maybe the screen you have is faulty, but since you didn't disconnect the battery it's most likely something was damaged on the board and will require microsoldering
完成的
添加一条评论
Thanks for the reply. Yes, I was very cautious with this phone and made sure the battery was disconnected. I will try using a flashlight
这个答案有帮助吗?
得分 0
1条评论:
I should also mention while checking on iCloud the phone showedboth my location and that the phone was on.
完成的
添加一条评论
I have no idea where to find a micro soldering places
这个答案有帮助吗?
得分 0
添加一条评论
The same problem, only, I replaced it with the new display and it worked on the test, it did the problem once when the screen didn't work after a restart, then I disconnected it and reconnected, it worked.
The next day I changed the battery, but it didn't work anymore, it starts up because the sound is heard when I connect the charger. I checked all the plugs, all the circuits on the screen and it is intact and new. what to be?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josh Andrews 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 47
总计 5,354
