跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
Will not display after screen replacement
I replaced the screen on a 2016 MacBook Pro with touchbar, after the screen was replaced when it boots up, it will not display to the screen, however will still display to an external monitor. I can get the screen to display on the laptop when I boot to an external drive sometimes, and I have tried another screen, and I get the same result. Installing the original screen solves all these issues and it works as normal. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Have you tried an NVRAM reset? https://support.apple.com/en-us/HT204063
完成的
I've tired, and unfortunately had no luck
完成的
添加一条评论
2个答案
最有帮助的答案
@butch00772 I would return the display as its defective! The only other possibility is you damaged it in the process of installing it.
While these displays are very expensive they are quite easy to replace. The backlight cable is very sensitive in the newer 2016 & 2017 models as the cable is a bit short so it stresses at the connection point at the T-CON board.
Review these:
这个答案有帮助吗?
得分 1
添加一条评论
I’d see if there is a connection issue on the screen cable. The connection might be bad. In addition to this, you might be suffering from the "stage light” issues that were explored by iFixit. If that doesn’t work, try an NVRAM reset, and if it still doesn’t work, the problem is somewhere else.
这个答案有帮助吗?
得分 0
1条评论:
I've checked the connection, and it appears to be fine, I tried to update the MacBook, it was running High Sierra, and after the update to Mojave it displayed with no issue until the computer rebooted, and now it's having the same issue
完成的
添加一条评论
添加你的答案
Butch Siragusa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,061
