跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Power button creating weird situations
Hello,
I received a iMac (2133) to try to fix from a friend who received it from another friend. First thing that is noticeable is when I try to power it on, I can hear the HDD spinning and the chime goes off and the screen turns white then shortly after it turns off, however if I hold the power button then sometimes it will boot normally just fine.
Second problem, when it does boot a fan is at high speed all the time being really annoying.
Third problem- how can i reset everything? i do not have the admin password and was wondering if there is a way?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
From the sounds of it I suspect your PRAM battery is dead. Here’s the guide you’ll need to follow to get to it iMac Intel 20" EMC 2133 and 2210 PRAM Battery Replacement You should be able to pick up the needed battery locally 3 Volt Lithium battery BR2032
See if after replacing it your system starts up correctly after you’ve corrected the date, time & startup disk settings in your preferences.
As far as resetting things without knowing the admin users password you’ll need to wipe the drive and re-install the OS and Apps. You might want to first boot up under an bootable external drive to you can copy off everything first.
这个答案有帮助吗?
得分 1
13条评论:
And what about the fans always at max speed?
完成的
All related! Until you replace the battery we really can't diagnose anything further.
完成的
ok i will try to replace this as soon as possible
完成的
Hey I got a question,
Is it ok to use a CR2032 battery or does it have to be the BR2032?
And also How would I wipe the drive?
完成的
The CR2032 will work as well.
To wipe the drive you'll need to create an OS installer CD or setup a bootable FireWire boot drive so you can boot up under it, to then run the OS installer from it. I would recommend locating the original OS installer grey CD/DVD disks.
完成的
显示更多的8条评论
添加一条评论
添加你的答案
JohnnyS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 148
