跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone 7 P Wont charge when phone is sleeping
Had a iphone 7 plus come in for no power, replaced tristar and it powers now but wont charge when the phone is sleeping. Has a steady 1amp pull while booting to lock screen, the moment the screen goes black, power draw falls to 0. If i wake it power draw is around 0.3a.
Tried a second tristar, replaced tigris and q2101 next to it, new charge port and battery with no change.
Hoping someone has either seen this or can point me in the right direction what to check next.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Try another battery and check battery connector. A bad connection to battery can cause this weird behaviour. I had it happen in a iPad air 2 before.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, I did check that and they seem ok. I think its gonna be the signal from the big power ic to tigris. I did audio ic repair on this phone about a year and baseband repair couple months after so the traces in the board may be just failing.
完成的
Took another stab at the phone after all this time, the battery was damaging the connectors. So I had to replace the connector and battery. All good now.
完成的
添加一条评论
Ben is right, try the battery connector. It might also be that you need a new charging port.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joel rakich 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 79
