跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Battery stuck on 1% and restarts randomly, after screen replacement
After replacing the screen of my iPhone SE the phone is stuck at around 1% (highest I’ve seen it go is 5%). All I did is replace the screen and the only touching of the battery I did was to unplug it so I did fry the screen. I have already tried turning it off and on as well as unplugging and plugging back in the connector to no avail.
Any suggestions would help, also if you know how to fix the problem it would be greatly appreciated if you could what I’d need to do to fix the problem.
If you need to ask any questions ask away.
Thanks, Tom.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL2400, at the top-left of the connector. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tom Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 101
