跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Why is my home button clicking but not working?
I inherited an iPhone 4S from family, but the home button does not work. It clicks and feels right, but it is a pain whenever my phone freezes or my jailbreak gets into a boot loop. Is this related to the home button cable on the screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do yourself a favor and take the jailbreak off. I have literally had phones that didn’t recognize chargers work right after resetting the settings.
这个答案有帮助吗?
得分 0
3条评论:
It was doing it before the jailbreak; it's a home button problem, not power.
完成的
It's on a small flex deep inside the screen. If you change it I'm sure it will work. May have even slid out of the connector and might not have to change. Most likely the little point on the black tip of the bulb is worn out. Replace with a new flex if so
完成的
I tried pushing where the connector is, and I'm avoiding disassembling the device, as the screen requires a complete disassembly of the phone.
完成的
添加一条评论
添加你的答案
TheYootz Media Group 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 99
