跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Replacement battery no longer working
Last week I replaced a battery in the early 2013 MacBook Pro that our company has. After installation everything turned on and sounded great and the end user calibrated the new battery with no issues.
Fast forward to this week: User can’t use the laptop unless it’s plugged into the charger. System information shows that the battery is fully charged although it has 0 cycles and the Amperage is 0.
I’ve reset the SMC and PRAM and opened the laptop back up and the connections look good. Stumped at this point!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You probably got a bad quality battery. Try using ifixit’s battery. MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417.图片
产品
$79.99
这个答案有帮助吗?
得分 0
2条评论:
That's where the replacement battery came from :-(
完成的
So go to ifixit support because your battery is probably defected. If I helped you please accept my answer.如何接受一个答案
完成的
添加一条评论
添加你的答案
Ashley Assink 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 51
