跳转到主内容
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33 个问题 查看全部
How can I fix droids back ground lighting?
ddroid got dropped in a bucket of water 1 month later turned it on and it worked sound mic everything even touch responsive only thing that doesnt it seems is the light for the screen.. only can see it if holded to a light and angled right... doesnt make sense cuz bottom symbols light up brightly? anything i can do to replace or fix it i dont want to buy a new motorola too much $$$...
oh and yes i even turned brightness up all the way....(took a long time though)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hey there. It sounds like you might have a broken backlight, a problem that could be fixed by first checking to make sure that all the cables are securely connected, and, if necessary, replacing the LCD. iFixit has a guide to help you out with this process. Take a look on ebay, amazon, or some other retail vendor to find a replacement part.
Good Luck, and let us know how it works out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,298
