跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Faint horizontal lines on the left side of the display.
Three days ago grey horizontal lines appeared on my Thunderbolt display. After a few minutes they disappeared only to appear again after a while. It happened three or four times and now they stay on permanently.
I connected the display to two different laptops and the lines were visible in both cases. I have also tried a new thunderbolt cable but it didn’t help.
Any help with pinpointing the issue would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
you're looking at potentially a display cable replacement internally. start with that and go from there.
完成的
Chris, I tried disconnecting the built-in cable and connecting the display via external port instead but the lines were still there.
完成的
I am beginning to think there might be an issue with the panel itself, right where the ribbon traces go to the display from the Tcon board. Basically where the internal cable meets the display controller board. From there is a strip of white or black tape along the top or bottom edge which can very pleasing be damaged even by touching it just barely. Other times they just flat fail.
完成的
Thank you Chris. As I said in another comment, I am going to replace the panel. I would hate to throw the whole display in a bin. It's good to have the issue pinpointed.
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly lines are a symptom of a TAB error. This is were the glass LCD panel electrical pathways is converted to a flex ribbon cable. The LCD has metal oxide deposited as electrical pathways within the panel the alignment or the joint of the interface has failed.
Sometimes a bit of pressure in the area can re-establish the connection otherwise you’ll need a new LCD panel.
这个答案有帮助吗?
得分 3
2条评论:
Agreed. I didn’t see this answer before posting mine but I was thinking the same thing. Well that just about confirms it then.
完成的
Thank you very much for the detailed reply Dan! I am going to replace the panel.
完成的
添加一条评论
添加你的答案
L Bul 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 1,270
