跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
Lcd issue? Only back light shows.
so here’s this iPad showing just back light but nothing else. I was thinking of replacing the LCD and fixing the issue this way buuuuutttt I didn’t wanna spend the money on it just yet without getting some feed back from you peeps? Can this be an lcd issue or something else??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is quite common, i know this might sound ridiculous but if you hold the iPad and give it a decent smack on the back it may well just fix your issue. Let me know how you go
这个答案有帮助吗?
得分 1
3条评论:
@will91491 You sir are a flipping genius!!!! I can’t belive it actually worked! I laughed and then went ahead and did it anyway and BAM!!! It’s working!!! This is quick fix, fix the same problem in other models??
完成的
Haha im glad to hear it worked for you, i have done this to many iPads that customers have brought into me over the years and i haven't had any come back doing it again, so i think it's a permanent fix but if it does it again you know what to do! It was most common on the 2nd/3rd & 4th gen models
完成的
Thanks man!!! You are a life saver!!!
完成的
添加一条评论
添加你的答案
wm_alvarez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 54
