跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
lightning connector replacement and factory reset
I replaced lightning and headphone part successfully in iPhone 5 according to iFixit guide but at reboot iPhone is as new device, like if I reset it to factory default and It asks to configure it as new iPhone.
It’s possible part replacement can cause factory reset?
iPhone is tuned off for many many months.
What happened?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
No, the phone de-activated itself meaning you’ll need to re-activate the phone either via 3UTools / iTunes or by going through the setup which will most likely ask for the Apple ID that was signed into iCloud on that phone.
Data should be there as devices only are factory reset from restoring the phone or resetting through settings.
这个答案有帮助吗?
得分 0
1条评论:
I checked by 3Utools and iPhone is activated.
完成的
添加一条评论
When I turn on It I have to choose Language, Country, Apple id … the same thing like a hard reset.
So you think if I configure device typing original Apple id I can restore data?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Riccardo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 136
