跳转到主内容
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
31 个问题 查看全部
8, I and k keys not working, replaced keyboard and same problem, help?
So a couple of weeks ago I spilled a drink onto my latop, completely soaking it in parts. The screen went black with only a few strips of colour at the bottom. I took it completely apart and dried and cleaned it out and reassembled it. Everything works perfectly now except the 8, I and K keys. Thinking it was from the water damage I ordered a new one and replaced it today but the same keys don't work. I'm worried I damaged something removing the keyboard ribbon as the clamp holding it was extremely difficult to open. If that's the case what exactly do I need to replace to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There might be a problem with the ribbon connector on the motherboard, as you might’ve damaged that when you were pulling out the keyboard, so if you have a way to test this, I advise that you test it.
这个答案有帮助吗?
得分 0
3条评论:
What methods can be used to test this?
完成的
The only real way to test this is by having a motherboard that worked from a different laptop of the same kind, which would require sautering to perform, and there might be a way to test it with a multimeter and checking the pins that those keys go to.
完成的
The top pictures seems to show a bit of corrosion by the ribbon cable. You can try using Q-tips moistened with isopropel alcohol to gently clean the corrosion off of the small components and traces. This may help with resolving the keyboard problem.
完成的
添加一条评论
添加你的答案
Becka Saurus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 30
总计 687
