跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
Is the protective metal cover for display ribbon cables needed?
I was an idiot and forgot to put the protective metal cover back over the display ribbon cables for the iPad Air 2 (as shown in step 30). I already applied the adhesive and finished putting it back together. I plan to purchase more adhesive and take it back apart to put the cover back on, however, my question is: can any damage occur without this cover (i.e. grounding, etc.)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can safely keep the device as it is. The brackets are designed to hold the connectors securely in place, especially during transport or if you handle your device roughly. However, most iPads live a simple life once purchased so the chances that a connector pops loose is quite low.
If this were an iPhone, it wold be easy to open it up again and make the correction. However iPads are different beasts and opening it up increase your chances of something else going wrong.
Worse case, you can always deal with it in the future if it happens.
这个答案有帮助吗?
得分 6
添加一条评论
添加你的答案
Daniel Hoynoski 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 198
