跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
No Display off boot
Hello all,
I recently acquired this late 2016 MacBook Pro A1707 15” with Touch Bar that was liquid damaged.
The battery was all puffy so I replaced it with an ifixit brand battery but I can not get the computer to boot into recovery or show anything other than the backlight.
I tried to reset SMC and NVRAM but I’m not sure if I did either correctly.
I can’t find the board schematic for this machine either and I don’t know where to go.
PLEASE HELP :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
there has been problems with the display cables wearing out over time on the 2016 models
这个答案有帮助吗?
得分 0
1条评论:
Like I said I have a backlight, I'm not sure where the display connector is located on the logic board but that could very well be my problem
What's the fix for this problem? If I take the laptop back apart is their a chance that the cable can still be used?
完成的
添加一条评论
At this point I think you’ll just need to bite the bullet and replace the logic board. Hopefully the rest of system is OK.
MacBook Pro 15" Retina (Late 2016) 2.6 GHz Logic Board, Radeon Pro 450, with Paired Touch ID Sensor
MacBook Pro 15" Retina (Late 2016) 2.6 GHz Logic Board, Radeon Pro 450, with Paired Touch ID Sensor图片
产品
$299.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sev 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 176
