跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
428 个问题 查看全部
Help please Honda Accord
2002 Honda Accord Car died on freeway gages jumped stereo flashed… So the headlights, horn, power widows don’t work car cranks but won’t start. We replaced ignition switch, main relay, MICU and left side fuse box. We’ve lost power to both interior fuse boxes and we are only getting 4 volts of power from main relay harness?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like something is shorting causing everything to ground out making the connection to them live. It would explain everything going on like the horn, lights and more as the current could pass through them completing there circuit and making them go off. I'd look for any exposed wires and things like that and of you're only getting 4v the rest of that voltage has to be going somewhere. Also check if the battery is still giving the required voltage out and if it is then follow the leads and look for any thing out of place from the origin to the end and work from there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremy L Carter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 67
