跳转到主内容
Samsung netbook with a 10.1" screen and 1.66 GHz Intel Atom N450 processor.
Why windows is not turn on (no response)
i have n150 plus that do not turn on i replace the ram but nothing i saw that power led and chrging is turn on but no loading
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Have you tried putting the original RAM back in your system to see if it will boot correctly?
完成的
添加一条评论
2个答案
If your power LED light is coming on, then your power supply is working.
But if nothing is showing up on your screen, here are a few fixes you can try:
  1. Check your computer’s brightness settings. Are they turned all the way up?
  2. Check for beeps or error messages. These codes may contain clues as to what’s wrong.
  3. Check your hardware. Are all the cables inside the computer secure? Is your video card in the slot securely? Is the RAM that you added in the slot securely? Try re-seating all your RAM, cards, and cables.
  4. The problem may be your software. If the screen is blank because there is a problem with Windows itself, you may need to reformat your hard drive and reinstall Windows.
If these fixes don’t work, please tell us what was happening before the problem occurred that may have caused it. Maybe some background information can help us help you better.
这个答案有帮助吗?
得分 0
1条评论:
It's possible the RAM he is using is not compatible with his system? That could cause some problems. Great comment about checking for beeps.
完成的
添加一条评论
i have the original ram installed in the pc
so what can i do in this?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
osher1446 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 235
