跳转到主内容
加入维修社区 - 创建账户
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Need RAM Holder Replacement
Hey guys, I went into my Macbook Pro today in order to replace the battery and I noticed the the top Ram slot is not seating the RAM. It pops up and it took me some intricate maneuvering to get it to seat.
Does anyone know the part # or piece to replace this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Your image shows the left latch (and I can’t tell but I think thats also true with the right side as well) has not be set. Carefully pull the black tab to the side slightly so the edge of the latch clears the module. Sometimes the latches go down instead of out as you press the modules down. Do make sure you’ve fully seated the module into the connector.
YouTube - Installing RAM
Reference: MacBook Pro: How to remove or install memory
这个答案有帮助吗?
得分 1
4条评论:
Thanks @danj I appreciate that. I think my case is a bit different. The tabs actually don’t snap anymore. So the issue is that the tabs don’t seem to be strong enough to snap the RAM in place.
I would love to just replace that part.
完成的
Sorry guy, just not possible ;-{
The clips are part of the connectors base. You would need to replace the entire connector which is just not possible.
I would still try to get the latches to grab. Maybe you need to help them a bit once you depress the Module into place slide them over. You might try an elastic band (a silicon version)
完成的
I found a solution which involves high temperature 3M Tape. I'll try that when it gets in.
完成的
Jamal Hartwell please post what solution you came up with as I have the same issue.
完成的
添加一条评论
I solved the issue by attaching an elastic band around either side of the arms. seem to hold well thus far
这个答案有帮助吗?
得分 0
1条评论:
Can i see a photo? Both of my ram holder latch is completely broken .. that's why
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 989
