跳转到主内容
The Epson Artisan 1430 is a color inkjet photo printer.
My printer is not recognizing the OEM cartrigdes
My Epson 1430W is making a werid problem. I had a failure with my printhead and motherboard, I replaced both. The problem was that it was not recognizing the cartridges. But after the replace of those parts is still giving me the failure.
It recognizes when I put 1 by 1 of the cartridges, but on the 6th it gives me the error. I checked the fuse F1 and its good. The board and the printhead are brand new
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
It does not allow me to do the update, it sends me an error. Any thoughts?
完成的
If you can post the error message it will be helpful. On printer display or computer etc.
完成的
I am having the same problem . I have exhausted everything I know. looking for any ideals
完成的
添加一条评论
2个答案
已选择的解决方案
I fixed my non-functional Epson printer with this procedure….
https://epson.com/support/updating-your-...
This may or may not correct the problem you are seeing.
这个答案有帮助吗?
得分 0
1条评论:
Did not help me still same problem
完成的
添加一条评论
there is a fuse on the main board fuse no.2 it is broken replace it and the issue will be solved.
it is caused by incorrect manual head cleaning.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
aemleal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 381
