跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
275 个问题 查看全部
New battery displaying incorrect percentage & dying around 30%.
Hey all,
Just replaced my Macbook battery and the charge is lasting a fantastic amount of time! Only problem I’ve run into is an inaccurate display of charge. For instance, Coconut Battery displays it at anywhere from 95-99%, while the icon on the top bar displays 100%.
I was in the process of calibrating it after an SMC reset, but noticed that it went to sleep at around 29%. I know we’re supposed to wait at least five hours so it fully drains before charging again, so I was concerned that it wouldn’t be enough time if it was still so high.
Any advice on this? Here are specs on the battery:
System Info:
Battery Information:
Model Information:
  • Serial Number: D8622873BQZDNMGAX
  • Manufacturer: SMP
  • Device Name: bq20z451
  • Pack Lot Code: 0
  • PCB Lot Code: 0
  • Firmware Version: 511
  • Hardware Revision: 3
  • Cell Revision: 1150
Charge Information:
  • Charge Remaining (mAh): 8071
  • Fully Charged: No
  • Charging: No
  • Full Charge Capacity (mAh): 8604
  • Health Information:
  • Cycle Count: 2
  • Condition: Normal
  • Battery Installed: Yes
  • Amperage (mA): -1670
  • Voltage (mV): 12058
P.S.: Other small issue, Dark Mode keeps switching off and back to Light Mode after shutting down and restarting. Mildly irritating.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You'll need to talk with the seller of the battery to get a replacement battery.
完成的
添加一条评论
1个答案
已选择的解决方案
The battery pack manufacturer is a major one but the electronics are faulty. Unfortunately there’s an awful lot of batteries with the same issues on the market, although a sudden shutdown at 30% seems worse than usual. Try contacting the vendor and explain the situation, they should replace your battery and maybe make them more responsible on what they place on the market. Differences between Apple and Coconut percentages are standard on newer machines, probably they take different references to calculate. I didn’t understand where you picked the 5 hours waiting before recharging, but it doesn’t make sense.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nare Mnatsakanyan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 360
