跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 个问题 查看全部
问题已关闭
Proximity sensor troubles (Works sometimes, sometimes not)?
Hi,
i've already read the related answers but that doesn't adress my problem. As i stated, the sensor sometimes switches the screen off during a call sometimes not. Hard reset didn't help. The phone was never dismanteled, but has had a hard life (well i use it a lot).
iOS 4.1 (8B117)
Modem Firmware (Baseband) 06.15.00
jailbroken and unlocked.
Any idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
My first guess would be that it's because you have the iPad baseband (6.15.00) installed. Though the dev-team says it's perfectly safe to use, it can cause all kinds of things to go wrong. I would consider looking around on Cydia for a tweek that disables the sensor all-together, or update the phone to a newer version of iOS (If you have saved SHSH blobs) and see if that resolves the problem.
这个答案有帮助吗?
得分 3
1条评论:
Thanks - i reseach into that direction. I'm a bit careful though, because the phone works fine otherwise and i don't want to loose my unlock. +
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,539
