跳转到主内容
问题已关闭
Remove Monitor lines
13 vertical lines on monitor
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Could be several things. If possible hook up an external monitor and see if you have a good picture. If you do its most likely the cable to the LCD or the LCD itself. If you don't its most likely the video card or the logic board. Let us know what you find out and we can do a better job of helping you. Ralph
这个答案有帮助吗?
得分 1
添加一条评论
Thanks for the help! Yes, I did try an external modem, and it worked great no lines and the picture was satisfactory for me.
Thus I think it could be the LCD, but the cable to the LCD could be the cause? Is it possible to replace the cable and save the money for a new LCD?
Thanks in advance,
Duane
这个答案有帮助吗?
得分 0
1条评论:
Yes you should be able to replace the cable and that would be a less expensive part. I would try that before replacing the LCD. Ralph
完成的
添加一条评论
Sorry to be a bother, but you've been a great source for fixing my iMac. Three questions: Where do you order a cable for my LCD, and does the cable come with some directions. Last but very important, price range for a cable.
Thanks in advance,
Duane in Hillman
这个答案有帮助吗?
得分 0
1条评论:
You need the repair guide and I've included the URL.Read the section on the display. If iFixit doesn't have the part you could try ebay> Ralph
iMac G5 17" Model A1058
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,779
