跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20011 个问题 查看全部
820-2936 quarter fan spin
so to start out i dont specialize in mac repair, i mostly work on phones. but a friend of mine had an issue with their macbook so i figured id take a look at it.
so everything is disconnected but the board and dc in board. it shows a green light on the charger and fan starts to spin up then stops. i checked all the main power rails and i found one that isnt right. pp5v_s3 is missing and its weird, when the fan starts to spin it shows 5volts for a split second the 0 again, and if i hook power to the board then disconnect power and test the line is shows as .006 voltage drop in diode mode but if u keep the multimeter probes on it starts to rise until its at like .400 i went over the entire board under a microscope many times and also looked at it with ir camera. i dont see anything that looks terrible. but im stumped and am hoping one of the experts on here can point me in the right direction.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You’ll need to spend sometime reviewing Louis Rossmann’s YouTube channel as he has documented a few different causes for your problem with a bad pp5v_s3. Get the schematics & board views so you can follow what he does and what trace or component needs to be repaired/replaced.
这个答案有帮助吗?
得分 0
2条评论:
that was step 1...lol
完成的
@mobilemedic - Step 2 is not down voting a fair answer!
Your expectation is we can tell you what competent has failed, thats just not humanly possible from afar. If I had your system in front of me I would take the exact steps I outlined to you.
Debugging a board is a process using the documentation and test gear to isolate out the failing component.
完成的
添加一条评论
添加你的答案
lukerockhill 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 9
总计 626
