跳转到主内容
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
49 个问题 查看全部
Is there an extension cable for the battery connection
I use my mi5 as a flight instrument. I want to get a bigger battery directly connected to the motherboard. Xiaomi do have bigger batteries but the connection cable isn't in quite the right place
I want to buy i.e. Mi max battery and buy an extension for the connection.
There's no back on the phone, size not important.
I don't even know what the connection is called.
Cheers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Probably cheaper and easier to just buy a power brick and a USB extension
这个答案有帮助吗?
得分 0
添加一条评论
This is on my paragliding flight deck and unfortunately what happens is the cable breaks, the phone USB breaks or the batteries USB breaks. They've all happen to me before .
I really need it connected at the rear of the phone with an extension or directly to the board.
Thanks though
这个答案有帮助吗?
得分 0
2条评论:
hmmm, maybe you can make a homemade case with either as 3d printer that could support both? or a bunch of ducttape plastic. ) ziplock container, with a hole cut for the screen, taped to the container, and the battery pack also in the container and all sealed up, idk. best of luck!
完成的
Thanks Dan, I've also been down that path before. I really want to do it this way. Cheers
完成的
添加一条评论
添加你的答案
Jaded b 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 113
