跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Camera problem after screen replacement
Hi!
I replaced the screen for iPhone 6s plus. Now the cameras arent working. If I havent plugged the front camera connection in, then the both cameras are black. If I disconnect the front camera the rear camera starts working fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If rear cam works after disconnecting front cam then you’ll need to replace the front camera assembly. Most likely due to a torn flex.
iPhone 6s Plus 前置摄像头与光度感应器组件更换
iPhone 6s Plus Front Camera and Sensor Cable
Replace a front camera and sensor cable compatible with the iPhone 6s Plus. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00153-A.图片
产品
$55.99
这个答案有帮助吗?
得分 0
1条评论:
So you think this is not a board issue? Will 6s camera work, I have one laying around?
完成的
添加一条评论
Most likely you damaged the front camera assembly during the repair. This can be a hard piece to remove if you don’t have a lot of experience. Did you just pull it off the old screen? In the future, a little heat will help loosen the adhesive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lauri Pahkala 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 177
