跳转到主内容
The Galaxy J6, released in 2018, is the successor to the Galaxy J5.
52 个问题 查看全部
Touch screen is not working after the update
Recently i changes my J6 display due to crack. Today i recieved the software upate and i updated it.
when the updat finish and phone restarted, the touch screen is not working.
What is the solution ????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Did you back up you'r phone before updating?
完成的
Nope. i did not expect that
完成的
Can you try plugging it into a PC and backing up like that?
完成的
how to fix it?
完成的
添加一条评论
6个答案
最有帮助的答案
Could be a weird bug with the new update. If you can, try factory resetting the phone. You could have also just had unlucky timing and the screen just decided to die on you. Most likely it’s some kind of software issue.
这个答案有帮助吗?
得分 1
添加一条评论
Touch is not working correctly
这个答案有帮助吗?
得分 1
添加一条评论
Change original display ( combo )
See you your job done.
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
At this point, presumably, you have already got a solution.
Just for the record:
You can connect a usb mouse using an OTG cable to operate the device. For backing up data, you need a bluetooth mouse to operate the device freeing the charging port to connect the phone to a computer.
Then you can enable usb debbuging and oem unlocking and go after a file to patch and fix the actual problem, without having to disassemble your device and avoiding the risk of losing your data.
这个答案有帮助吗?
得分 0
添加一条评论
The screen is totally off
这个答案有帮助吗?
得分 0
添加一条评论
There is no Drive app on my device
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
isfaak 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 10
总计 2,706
