跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Display Problem couldnt solve by changing screen?
Hello I’m Sinan!
I have MacBook Pro 15’’ Retina Mid-2015.
Since last month my screen doesn’t work. When I use TV or another screen with HDMI MacBook works perfectly.
When I took my computer to Apple service they said I should change my screen. But new screen also didn’t work. They said display connector on logic board has some oxidization so we have to change logic board and screen…
Of course I did not accept that because it is too expensive for Mid 2015. At least I can use it like desktop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I disassembly logic bord and clean display connector with isopropyl alcohol but did not change anything. Also I change LVDS cable but again did not change anything
完成的
What do you suggest about my situation?
Thanks for your help and sharing your experience with me
完成的
添加一条评论
1个答案
已选择的解决方案
Who’s “they”, Apple?
Apple will always suggest a logic board replacement if some component like the display connector fails. It sounds to me like you will need microsoldering repair on the logic board’s display connector though from some specialist like Louis Rossman (for example…).
I can’t speak for how much a display connector repair would cost, but it will be much cheaper than however much Apple is charging.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your respond. Yes Apple. In Istanbul its hard to find a specialist as you mentioned but I will try to find.
Thank you again
完成的
添加一条评论
添加你的答案
Sinan Meric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
