跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 no power, not charging
not showing anything, not even the “needs charge” icon after getting wet, then working for a bit. i opened up to dry it and blew it out, even under cables and such. then, it powered on, but home butting not working. then i powered off to reinstall sim card, now nothing, nada, zilch. what did i fry? what can i do? i am willing to attempt any repair and have experience.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Clean your logic board and other components with 99% isopropyl alcohol to clean up corrosion. Then try and power on. If not, something is either shorted or a component is damaged. This is pretty difficult to find the cause of your issue, but there is a technique called rosin smoke. You get some solder rosin and dip your soldering iron in the rosin to then cover the components with the smoke given off by the rosin. Then try to power on, which then the faulty component gets really hot cleaning itself from the smoke. Now the proper area in the logic board is hard to find, so you may just want to smoke the entire board. If it’s not a short this technique most likely won’t work, but worth a try.
Technique can be found here: https://www.youtube.com/watch?v=Lq1zmfwt...
it is a different repair, but the technique is the same.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
carissaspatcher 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 74
