跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Phone touchscreen works before pressing it into body
I replaced the phone screen on my iPhone 8 Plus and tested it before placing it into the body of the phone. The phone reacts to touch until it is clicked into the bottom of the phone then immediately looses response to any input.
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
There could be a problem with the ribbon cables when the device is closed, they could possibly be getting pinched when the display is put back in, which would disrupt the touch.
这个答案有帮助吗?
得分 0
1条评论:
Could be the case. When putting the back metal shield over the screen cables the screen cables should align with the black markings on the metal plate. It should be not going past the marking so that the cable doesnt get squished or put in wrong direction.
完成的
添加一条评论
After you put in in you said it doesn’t work. If you take it back out will it work again? If yes you’r probably pinching a ribbon cable and just put them is differently. If it doesn’t work anymore you must have broken the screen and you would need to buy a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
K_Ar_S_O_N 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 66
