跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Is the LCD from the iPad Air compatible with iPad 6?
Hello-I am working on multiple iPads for a local school district. Had to do just an LCD repair on one of their iPad 6’s and they brought me iPad Air LCDs to use for the parts. However when I install both of them, they have a distorted image and cause a boot loop. They physically fit and line up properly so was wondering if anyone knew exactly? I don’t think the parts are brand new.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Not compatible.
The iPad air 1st gen LCDs only work on the air 1 and 5th gen but not the 6th generation one due to different display driver.
这个答案有帮助吗?
得分 2
1条评论:
Thank-you very much!
完成的
添加一条评论
No they are not supported. You have to use the proper LCDs in this model. It will kinda work but it will have distortion like you mentioned above.
You can read more about the compatibility between the two at: https://ifixit.org/blog/8977/2017-ipad-p...
这个答案有帮助吗?
得分 0
1条评论:
that blog is about the 5 vs. the air. doesn't mention the 6
完成的
添加一条评论
添加你的答案
Lucy Larkin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 4,153
