跳转到主内容
加入维修社区 - 创建账户
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Reboot when i'm calling
When the dock connector is connected, it will restart.
I changed the dock connetor, but it not good.
What is the problem? :S
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I may have a problem with the battery. (Really doubt that it’s the battery) it probably needs logicboard repair.
完成的
It sounds like you either need a replacement earpiece speaker or top components flex cable replaced. If the earpiece is not connected properly, any time it attempts to make sound through that speaker, it restarts the device. Should be as easy as top flex cable and earpiece replacement.
完成的
There have been a lot of problems with the dock connectors. Does it do that with a regular iPhone charger?
完成的
添加一条评论
1个答案
最有帮助的答案
Front camera cable must have been ripped, this would be a fault caused by the proximity sensor somehow being damaged. See if it reboots with front camera disconnected.
Siri also uses proximity sensor so see if it reboots when you try to run Siri.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ttdarabant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 213
