跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
3D Touch on replacement display not working properly.
I recently replaced my iPhone 8 screen with a replacement from iFixit.
The 3D Touch function is very sensitive. Almost so its unusable, is there a solution? Is it perhaps software based?
Also it seems the refresh rate of the display is lower than the original?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
3D Touch requires individual calibration, the replacement screen will always have wrong calibration data. The only way is to keep swapping screen to find one more or less matches.
这个答案有帮助吗?
得分 1
7条评论:
You can recalibrate by resetting the phone
完成的
Like a factory reset and then restore from backup?
I only bought the one screen so can’t really swap around.
完成的
Back up your data so it isin't lost and a factory resent my not calibrate it but thy say that's the most calibrating you can do on a iPhone.
完成的
No it is not possible to recalibrate by using reset all settings. Connection to Apple internal DisiplayCloud and using the Horizon Machine to test pressure sensitivity is required.
完成的
I did a full reset and that didn't solve it.
I find it odd that iFixit wouldn't list this as a potential problem when switching screens.
完成的
显示更多的2条评论
添加一条评论
It’s most likely not a very good screen that you got. You may have to try another one if you have it, are you able to put your old one on and see if that’s any better?
这个答案有帮助吗?
得分 0
1条评论:
I could but i know 3D Touch worked on the old one since i often used it.
完成的
添加一条评论
Go to settings/General/Accessibility/3D touch and from there you can set it to Light/Medium/firm. Your probably set to light in order to make it less sensitive set it to medium or firm.
这个答案有帮助吗?
得分 0
1条评论:
I tried the settings and that didn’t help.
完成的
添加一条评论
Did you replace the water seal on the device? that helps with 3d touch also I believe.
这个答案有帮助吗?
得分 0
1条评论:
I did not.
However i switched back to the old display and it works fine without water seal.
完成的
添加一条评论
添加你的答案
Martin Carlenfors 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 421
