跳转到主内容
加入维修社区 - 创建账户
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
How to remove the virus bitly.
A virus named bitly has begun putting annoying popup ads on my phone. It has taken over the reboot sequence and has disrupted the operation of the phone. If you can't help remove iy, do you know who designed it so I can beat him with a bat.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @imbuildr
If data is not important, you can consider this
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
https://support.t-mobile.com/docs/DOC-27...
这个答案有帮助吗?
得分 3
添加一条评论
Hi, you can also use the CMD to remove virus:
Step1: Launch Command Prompt by going to the search box and run as an administrator.
Step2: Once cmd opens, type D: and hit enter. (Replace D to the wanted drive letter)
Step3: Now, type the command attrib and hit enter to execute. You will be able to see the autorun.inf virus files in the listing.
Step4: Input the command attrib -r -a -s -h *.* and hit Enter to execute. This command will delete the read-only, system, archive, and hidden file attributes from all the files. (*- is for the files with different extensions).
Step5: After this, type del autorun.inf command and press enter to remove the files. In case you are infected by any other virus, then replace autorun.inf with the extension of the virus your system is infected with such as .exe or .ink.
Hope can help you!
这个答案有帮助吗?
得分 0
1条评论:
Hi @amimi ,
The question was about a ZTE ZMAX mobile phone with a virus problem
The phone operates on an Android OS not a Windows OS so your answer will not work.
Please look at the question fully before answering
完成的
添加一条评论
添加你的答案
Terry pold 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 419
