跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Why isn't the solder melting?
I have a Nintendo switch that has a broken port I bought the tools and equipment for it and have set the temperature on my hot air rework station set to 350c but no luck and I even tried putting flux but still nothing, I don't know if I am giving it enough heat or I am missing something, I am a newbie when it comes to this stuff, any help would be greatly appreciated, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have the same issue but I was able to get it off but there is old solder left in the four holes and it is preventing the port from sitting flush
完成的
添加一条评论
1个答案
已选择的解决方案
The Type-C port requires a lot of heat to remove. Have you added leaded solder on the charging port pins to lower the melting point of the solder?
Leaded solder has a lower melting point compared to non-leaded solder which will be what the components on the logic board are soldered with.
Check out this video for reference:
https://www.youtube.com/watch?v=Wfx3ShJC...
A board preheater (This helps a lot) is used along with a soldering iron and a hot air gun at the same time to remove the type-C port.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Miguel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 35
总计 3,422
