The charging port got ripped out of my drone.
Its actuly a syma x20 but its not in the list. Is there anything i can do?
Hi @ahrongutwirth ,
Here’s a link to a video that shows how to replace the charge port in your drone.
You will need SMD (surface mounted device) soldering skills and tools to do the repair.
I couldn’t find the correct replacement connector for the drone on places such as Ebay etc so if you can’t find one either check here to find a suitable replacement connector if yours is damaged rather than just loose.
The main thing to look for is that it is the correct type and that the connector’s external board mounting “lugs” (not the pin connections) are situated in the correct place so that you can solder it to the pads provided on the board, so it is secure.
Look at the datasheet for the connectors you think may be appropriate and compare it to yours or what you need
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 162
