跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61 个问题 查看全部
Why tablet won’t turn on after digitizer replacement?
Got a mini 2 cellular tablet from a friend that said someone replaced a cracked digitizer but then the tablet wouldn’t turn on. So now I’m looking at it and when i took it apart the battery connector didn’t seem fully connected in. I checked the ipad with a tristar tester and everything was ok but it said the battery wasn’t connected.After i disassembled it it took a charge with high amps 2.12 or so then gradually went down to zero in the morning. So now reassembled it wont turn on. Strange that person wanted to keep divice after it wouldn’t work for parts… besides replace screen to see if it (suddenly went bad) Can you think of anything that i’m missing ? Thanks for your thoughts !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I would certainly try a new digitizer to see if that helps. In the meantime, disconnect the digitizer and LCD (disconnect the battery first!) and then connect the iPad to an iTunes enabled computer to see if it boots and is recognized. If it is, then add the LCD first (again…disconnect the battery first!) and test again. If it works, then try to add the digitizer. This should help you identify the bad part if that is the problem.
If the device boots and is recognized but you can’t see anything on the screen, the you need to determine if the backlight and LCD driver circuits are working properly. Try shining a bright light on the screen to see if there is a dim image or not.
If the iPad doesn’t boot with no LCD or digitizer, then you may have a deeper logic board issue.
这个答案有帮助吗?
得分 2
2条评论:
Disconnected the digitizer and now notice the apple logo at start up then it goes right too connect to itunes, although i did not put it into that mode. I guess easier to put a good LCD on it to see if back light in LCD is the problem ? Thanks in advance !
完成的
Now iPad plugged into charger is taking 0.20 amps , was not taking anything before but a few hours after I charged it the first time.
完成的
添加一条评论
If you aren’t careful when taking off the digitizer you can easily brake the wire connecting the power and volume buttons to the logic bored. In order to know if this is the reason you should start charging the iPad and see if it turns on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Perry Green 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 534
