跳转到主内容
主板和 CPU 维修指南。
166 个问题 查看全部
My front USB ports do not work
I own a Corsair 460x and a Z270. One of my front USB slots gives out power but does not recognize some devices while the other one does not work at all. I faintly remember it working when I first made the PC. I have uninstalled the drivers but there is no change.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hey Alex! It sounds like either an issue with the motherboard, or an issue with your operating system. I’d say it’s likely the motherboard headers. Since you built this PC, I imagine you know your way around it, so I’ll give you a straight answer here. Try taking the side panel off and messing with the USB headers, maybe blow out the connectors, or try reseating it at the very least. Also, do your front panel audio jacks work? If it’s a motherboard issue, they’d likely have some sort of issues. Good luck!
这个答案有帮助吗?
得分 1
1条评论:
Hey I'm going to try do that. Also the Front audio jack also does not work. Thanks for the help :)
完成的
添加一条评论
添加你的答案
Alex Anderer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 8
总计 1,889
