跳转到主内容
加入维修社区 - 创建账户
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Home button stopped working
I replaced a lot of things on an 8+ and after putting everything back the home button stopped working. The screen wasn’t replaced but the homebutton was the only thing that stopped working. Could it just be the ribbon cable that connects to the logic board and if i wan’t to keep touch id would it still work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Chances are the cable for 3d touch and home button connection got damaged.
As long as the home button wasn't touched replacing the screen will fix that problem.
If you haven't already try reseating the screen connections while battery is unplugged.
这个答案有帮助吗?
得分 1
添加一条评论
Sad thing is: iPhone 7 and 8 don’t have a real home button. The button that came with the phone is the only button that will work. You can’t replace the button, or else it won’t work in any way.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Axel Salas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 122
