Poor idle on Honda mower model HRR2168VKA
I recently decided to sharpen the blade on my mower. I shut off the fuel valve before tipping to its side, only later to find oil would poor out of the air cleaner causing a failure to start. I began to clean off the oil by removing saturated air filter. After initial cleaning, it wouldn’t start. At this point, I decided to further clean the spark plug. Second attempt to start momentarily with a lot off smoke. I figured further cleaning was need so, removed carburetor to clean out the float valve, main nozzle and float in carburetor. After carburetor cleaning and filling up to proper level of oil, it had a rough start but, but, got it to idle after several attempts. The Idle is rough and goes up and down non-stop. I checked for air leaks but, couldn’t find any. I don’t see any adjustments for carburetor control. Anyone have any ideas what can be causing poor idle?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
