跳转到主内容
加入维修社区 - 创建账户
Released in 2013, the Model #412540 is a Wifi connected portable music device using Android or Apple devices downloaded with the SoundTouch app.
SoundTouch Portable won't turn on. New battery.
I recently purchased a non-working SoundTouch portable. The seller thought it was just the battery, but that does not seem to be the case.
I have tried hard resets but am not having any luck.
Bose Support has stated they can fix it for me for $99 if I send it to them. I’d like to see if there are things I can do before sending.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
I’m looking for a way to eliminate the battery, as I can do without the portability.
When I take out the battery, the unit will still not boot.
Does anyone have a schematic of the unit, so I can bypass the battery and just use it on the dongle AC power?
完成的
I ended up sending it to Bose to have them fix it.
I did check continuity and some other things, it seems that my issue was a blown board.
完成的
@Joseph, did you ever find a way to use the speaker? It is really annoying to me that it won't work without a battery, I have replaced mine twice even though I never needed portability. I really don't want to buy another battery.
完成的
添加一条评论
4个答案
Hey Joseph,
Seems that I have a very similar problem as yours.
Unit does not show any signs of life.
I replaced 2 caps on power pcb that were slightly expanded. Still no life.
When I measure volts on batery terminals on a speaker side, I get 18V. However when the battery is connected, the most I get is 8V.
11V battery can’t get charged with 8V. And batt is dead completely. Nothing on any terminal.
Have you figured it out if unit can be operated on AC power without a battery?
Thx
这个答案有帮助吗?
得分 0
1条评论:
I have a similar problem. New battery - 20 V on the power supply - factory reset and updates done - battery won't charge. I need some advice on whether this is a hardware or software issue?
完成的
添加一条评论
Same seem to have happened to my unit after I was forced to upgrade to the latest firmware.
这个答案有帮助吗?
得分 0
添加一条评论
If the battery is not charging (and app. stops working because empty battery) then a condensor of 10uf/35V is defective (to high ESR). Naer the coil.
这个答案有帮助吗?
得分 0
2条评论:
Dear Edzard,
can you please describe a bit more detailed what capacitor you mean?
I do not understand "Near the coil", what coil you mean.
完成的
Yes - a pictures would be very helpful.
完成的
添加一条评论
It happens to me that the system turns on but is disconnected from the battery and the speakers do not sound. Is it the battery that is defective or the motherboard?
这个答案有帮助吗?
得分 0
1条评论:
Is the Soundtouch playing music and it doesn't sound or is there no music?
If the sound is poor, it may be that the speakers aren't properly seated in the enclosure. The back of the speakers must be airtight.
完成的
添加一条评论
添加你的答案
kyhokie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 44
总计 1,743
