跳转到主内容
MacBook not running off battery after replacement
The battery in my MacBook Pro A1425 was draining fast and had to be charged constantly, so I decided to buy a replacement.
I replaced the battery, it’s recognized by macOS, but it won’t run on battery power, and it says it’s not charging. It only runs with the power cord connected.
I tried to put the old battery back, but it now has the same problem, won’t run of the battery.
So now the new battery is back inside.
Tried resetting SMC a couple of times, but no difference.
This is what coconutBattery tells me.
What is there left to try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It’s possible you got a bad battery, I’d try changing it again. Maybe this time from a different vendor.
这个答案有帮助吗?
得分 0
添加一条评论
Any Luck with this ? My A1425 does not recognize the battery after I changed the trackpad. I am getting ready to change the battery considering that it is about 5 yrs old and probably done with the cycles. But just wondering if I might run into this issue since I had no issues with the battery prior to replacing the trackpad.
这个答案有帮助吗?
得分 0
1条评论:
Nope, no change. I have not tried replacing the battery yet again.
I replaced it with another battery before the one that is currently inside, that one did not work either.
So I have tried two replacement batteries, and the original. And neither of them is charging, or can be run on battery alone.
完成的
添加一条评论
添加你的答案
Jens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 160
