跳转到主内容
Find repair and detailed information about the Samsung Refrigerator RS265B***, a side-by-side model with a built-in ice dispenser, released in 2006. This page covers information for model numbers matching the pattern RS265B***.
Samsung RS265 side by side not dispensing water
Both the water dispenser and ice thermostat quit working over a short period of time. I replaced the ice maker, which solved the ice dumping issue, but I can’t figure out the water dispenser. Good water pressure on incoming lines, I replaced the water valve and have cleared the lines from valve to door, and can hear the water dispenser making noise when pressed. Would it be a bad relay somewhere that’s not allowing the water valve to open? If so, would it likely be on the dispenser or main circuit board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I have had a similar issue with my side by side fridge dispensing water and Yes mine was a solenoid relay in the back of the refrigerator always make sure to have the refrigerator unplugged when messing with electricity. Also on the back of the refrigerator should be a wiring diagram in a little plastic envelope taped to the back usually down on the bottom behind the plate for the compressor sits.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
J V 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 148
