跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Replaced with bigger SSD -- now it's running slow/hanging
Hi all -
I’ve been reading through the answers and throughout Google to try and figure out what’s going on with my mac.
I replaced the original drive with a larger SSD (Aura) following the guide on here and another site. Now, my computer will be working fine at one point and all of a sudden slow down and often hang - sometimes with the beachball, other times not.
It’ll usually come back just fine after a little bit, but it never used to do this.
I read about the SATA cable being an issue in previous macs, but I don’t see anything like that for this model.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Retina systems don’t suffer from the same issues the Unibody systems did.
Unlike them, your’s has the drive directly connected to the logic board. In your case you could have damaged the drive socket when trying to remove or installing the SSD drive.
Disconnect the battery and carefully remove the SSD. Take a picture of the SSD as it now sits, then few tight & sharp pictures of the connector so we can see into the slot as well as see the solder joints of the connector Post them here for us to see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 56
