跳转到主内容
A1150 will not charge. Can one replace the charging circuit?
I have a used A1150 (eBay) and it has never been able to charge at all. I followed all the troubleshooting guides from Apple's tech pages and went to my local Apple tech store. They switched the Magsafe and swapped the battery. Their battery worked fine but the Magsafe charger still did not work (it holds a very dim green light when attempting to charge). They said it probably was not the logic board but the actual charging circuit. What part(s) would I need to replace the charging circuit? can one replace the charging circuit without soldering?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Do you mean to say they swapped the left i/o board? (the part with the magsafe board)
完成的
添加一条评论
4个答案
最有帮助的答案
yes, the charging circuit should be on the left I/O Board, you can find the repair instructions here - replacing it does not involve soldering.
这个答案有帮助吗?
得分 1
添加一条评论
They only switched the Magsafe adapter not the left I/O board. Sorry for not qualifying that. @rab777hp
Great tutorial @bac. i will grab a few tools and find a replacement left I/O board. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
Are you sure it's not the battery? The computer end of the Magsafe on this model of Macbook Pro glows red when the battery is depleted and green when fully charged.
这个答案有帮助吗?
得分 0
添加一条评论
My bet would be the Left side I/O board. Not difficult to replace, but parts getting hard to come by!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve 10 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 5,999
