跳转到主内容
The Nextbook Ares 11 NXA116QC164 is an Android tablet with an 11.6-inch display released in 2015.
14 个问题 查看全部
Will not charge at all.
This tablet will not work due to the the charging port not working. How do you replace or repair it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @andyanderson489 ,
Here’s a link to the ifixit Nextbook NEXT7P12-8G Battery Replacement guide.
It is useful as it shows how to open the tablet to gain access to the DC-In port.
As it appears to be an SMD component (surface mounted device) first check if it is loose from the systemboard.
If it is loose (or even if not and you have to replace it), you’ll need SMD soldering skills and tools to do the repair.
Here’s a link to just one supplier of the part. It is shown only to give you an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Nextbook NEXT7P12-8G DC-In jack to get results.
If repairing the port seems too daunting, contact a reputable, professional, electronics or mobile phone repair service and ask for a quote. It may be cheaper if you dis-assemble the tablet and have the replacement part and just get them to do the SMD soldering removal/replacement and you will re-assemble the tablet afterwards to cut down on the time spent on dis-assembly/assembly etc.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Anthony Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 194
