replaced lcd replace will not slide to unlock
i replaced the lcd screen in my 2nd gen itouch. it lights up perfect like new but not touch screen controls. is that through the lcd or glass screen?
Double check your connections, the digitizer(glass) can be a bit of a pain to get to stay.
这个答案有帮助吗?
i did check but no luck
I am having the exact same problem! I have an ipod touch 2nd gen that I recently bought off ebay and the only problem the guy said it had was the screen would not open. I opened the ipod touch, cleaned it and looked around at the parts and everything looks ok, though I noticed from the headphone jack that the ipod has gotten wet. Everything else from what I know so far works great. The ipod powers up, is recognized by itunes, the battery charges, lcd screen works, I have restored it several times, updated the firmware, and it syncs. I have tried two different screens: #821-0627-03 and 04 but neither is working. I am about to pull my hair out trying to figure out why this screen would not be working! I keep looking at the connector thinking it may have some corrosion inbetween the pins but I can't tell (even with a magnifier) if that's just the color that's off or actual corrosion. I have cleaned the connector also with 90%+ Alcohol, too. Help Help Help PLEASE!
这个答案有帮助吗?
I received another digitizer ending in 'o6' and it does NOT work either. UUUGHH! I am starting to feel it's the logic board. :( say it aint so!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,263
