Unable to activate iPhone 6
Never came across this before. Iphone won’t connect to my WiFi but still picks up signal. Has been updated and restored but haven’t been successful.
What is the History? When was it activated last? Why was it restored initially? Are you sure you are getting Wifi but not connecting to Wifi? Looks like signal is from Data (Sim), maybe try activating with another sim? Usually have a searching or no service if data (Baseband issue)… Is IMEI Clean? need just a little more info on what started it all and some background… Bad NAND programming can also cause it
这个答案有帮助吗?
iPhone 6 unable to activate try connecting your iPhone to iTunes to activate it, or try again in a couple of minutes
if this problem persists,contact apple support at apple.com/support
这个答案有帮助吗?
My I phone number 6 plus. But I have wrong right that can some want help me fit my wrong
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,647
3条评论
No it doesn’t. It says about it can’t activate the phone and it may need a sim pin in order to activate.
由 Ryan 完成的
will it activate using iTunes?
由 chris 完成的
No it doesn’t. Says it could be a sim activation but nothing comes up asking about a sim pin so I don’t know if it’s that. I’ve restored the phone through iTunes but still comes up with this
由 Ryan 完成的
