跳转到主内容
The Asus Zen AiO Pro Z240IC is an all-in-one desktop computer known for its 4K, ultra high definition screen and one terabyte hard drive.
ASUS ZN240ICGK-RA030T SSD+HDD? Replace or ADD
Model ASUS Zen AIO ZN240ICGK-Ra030t. Hello. Can I install a second SSD on this model? or just a replacement instead of HDD?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
No, there is only one SATA connector on the main board and there is not enough space to install a second disk. However, you can easily replace the original installed SSHD with a 2.5-inch SATA SSD drive.
Check out this guide to better understand how the components are allocated inside the case:
Asus Zen AiO Pro Z240IC Hard Drive Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nikita Ogienko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 452
