跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
LCD not as smooth
I added a video..
So this is a 2nd hand item. The screen cannot hold 2 press at the same time and it is not as smooth! its sticking. Tried changing the lcd with the same backplate and still the same! 3d touch is slow too! it’s like it has a default time for press. Should I change lcd or just go get a better model.
+will replace rear and front cam from an abandoned 6s
+yoobao battery or just go sell entirely
-touch id and double tap not working just home button
stressfull lol
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi
is this an aftermarket LCD or an OEM LCD
Thank you
这个答案有帮助吗?
得分 1
2条评论:
I also have the aftermarket one still the same haven’t tried original lcd attached
完成的
i would suggest trying an original one if you can get your hands on one. if that also fails then it will be a logicboard issue. but i think the screen is likely the cause of your issue
完成的
添加一条评论
添加你的答案
repairwhat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 99
