跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 个问题 查看全部
Why is hard to click and drag trackpad not working
i hardly use my trackpad most times i use my Kensington Roller Ball mouse.
i tried to use the trackpad without the mouse connected and found the two finger click hold drag not working. all other gestures seem fine. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Likely having an issue with your battery which is pressing on the trackpad from below.
Lets check the battery using this gem of an app CoconutBattery post a snapshot of the main window so we can see 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
1条评论:
Another possible scenario, since you're able to use gestures but not able to press properly, is that there is debris around the edges of the trackpad. So, as Dan suggested, first test the battery. If it seems to be functioning fine, attempt to clean the trackpad with a little bit of isopropyl alcohol.
完成的
添加一条评论
添加你的答案
Will 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 78
